bokagod
rgb controller for msi h61m motherboard
Mohd Noh    29
8 hours ago, bokagod said:
hey guys was planing to get di coolermaster masterbox5 with rgb fans but found out that i canot use the rgb fan on my msi h61m motherboard as it do not have an rgb header ...can i use this on my motherboard to connect the rgb fans?
https://www.newegg.com/Product/Product.aspx?Item=N82E16811999383&cm_re=rgb_controller-_-11-999-383-_-Product
Hello
Maybe you can check this : https://www.newegg.com/Product/Product.aspx?Item=N82E16811999379&cm_re=cooler_master_rgb_controller-_-11-999-379-_-Product
But please contact customer services , they will assist you .
Share i have old motherboard z97x with an intel ( i want turn on it to RGB )
And soon i will receive my RGB stuff with controller + Fans RGB
