valnuke
Mastercase pro 5 (what TOP cooling?)
Mohd Noh    29
16 minutes ago, valnuke said:
Hi, I have a mastercase pro 5
what liquid cooling (with radiators) are supported on the TOP? please suggest options
thanks
Im using MC Pro 5 with Master Liquid 240 on the top  + with aftermarket fans ( Jetflo ) and soon MasterFans Pro RGB 120mm
Mohd Noh    29
1 hour ago, valnuke said:
thanks, do you think I should go with a 280mm option?
I'm mounting a i7 6850k processor and a GTX 1080ti 11gb
240mm radiator also great + if you not Ocing your system .. well 240 is pretty good enough .
All its up to you man ... but if me i will get 240mm radiator and invest to others stuff
Currently im using z97x and soon my RGB stuff will arrive :)
