john smith
Hyper 212 led fan direction
Mohd Noh    29
Hi John ,
Can you give full detail like full stuff you have ?
Depend on the situation because generally cases setup as below with fans at the front < this setup is very good .
If you want to swap the fan to the back of the heatsink you should also remove it from the plastic fan holder & reverse it so that it is still pushing the air in the same direction.
You lose some cooling performance this way though over the standard fitment.
Please contact our customer services , they will help you .
Mohd Noh    29
24 minutes ago, john smith said:
The plastic back plate was broken also so if i could get one of them too that would be great
26 minutes ago, john smith said:
I have an Asrock  AB350 Motherboard. I see now that you have a bracket to mount it sideways how do i get one?
Please contact customer services , they will help you .
