George355
Rgb header problem
George355    0
Hy, I have a MSI H110 PC Mate and the coolmaster masterbox lite 5 as a case.
There is no RGB header in my motherboard so I want to know if there is a solution to that. Beside that I am want to know if I need the RGB cable to be pluged in to use the RGB light, I have the power cable for the fans connecte and they are working but the light dont turn on.
Mohd Noh    29
Hi George ,
Can you share specs and stuff you have ?
Im want share , i have old board z97x and im waiting my stuff arrive , in my mind i want build up an RGB into my system
Masterfans Pro RGB 120mm x 5 pcs
Cooler Master RGB controller
Cooler Master 1-TO-3 RGB SPLITTER CABLE
I will share to you once my stuff arrive and done doing the installation :)
