Joe
COSMOS C700P RGB Acting Crazy
Joe    0
So here is my situation with this case. I got the case back at the end of October and absolutely love the thing. I had the case RGB lights all set up and it worked perfectly with my M/B (I've been using Gigabytes RGB Sync to control the lights). Then a little more than a week or so ago it started acting up. Now at first I wasn't sure what was going on but the RGB on the case was no longer matching that of the M/B when the case RGB was on the M/B setting. For whatever reason the case seemed to be stuck on a light blue / cyan color no matter what color my M/B was at.  It is important to note that the case cycled through each color correctly in cycle mode and the static colors worked just fine too, it was just the M/B mode.
So I opened the case up and had a look inside, made sure everything was plugged in and nothing got loose. Doing so sort of fixed the problem but now I'm not sure what is going on. For purple, dark blue and light blue the color on the case and M/B are matching. But if my M/B is red, green, yellow and orange the case will be a random color, no rhyme or reason to it. Now I have no clue if this is a case issue or an RGB Sync issue at this point.
I know a few other people are having issues with this case and its RGB functionality. Anyone have an idea what might be going here or a potential fix?
Mohd Noh    28
Hi
Please touch our customer services , they will assist you .
Create an account
Register a new account
Sign in
Sign In Now
