Osiris
Aquagate Mini R120 Review by Osiris
Osiris    0
Hi guys,
Sorry I haven't been around for a while. I've been very busy with work.
Here's the review I promised for the miniR120. Installation was very
simple and set up was self explainatory. The only problems I ran into
were positioning the tubing in a way that does not kink them and disrupt
their flow. Initially when I tried to install it the memory sticks were in the
way of the tubing which left me no choice but to reverse it. That gave me
limited space to work with the fan and the radiator placement but it was
the best option. With a little tweaking, everything worked out just fine.
The unitl runs like a dream...very quiet, as long as you keep the fan at
the mid speed. (Turn it up and it sounds like a jet liner taking off!)
Instead of using the supplied fan, I used another fan that I really like
which pushes out 89 CFM at 36 DB. The temps that I am getting with the
processor set at stock speeds are 36C on idle, and 41C at full load.
With my workload, I haven't had the time to overclock my processor yet.
I'll let you know about that as soon as I get some time.
Mindless, to answer your question about the hose length, they are approx. 11 1/2" each.
Overall, I am very pleased with this product. Truely CM has made water cooling easy to install and maintainance free.
If there is anything I would change it would be to make the hoses clear with a cool colored dye running thru and I would
make the fan clear and with LED lights. That way, you can cover a larger market and it would look cool too.
Here are some pictures I took of the project. Hopefully you guys can get a good idea how this product looks.
Karma Ghost    0
Lookin' good. I think it was made of that kind of tubing so there would be no evaporation as opposed to using clear stuff.
8)
Cobra19    0
So is it possible to change the tubing and the liquid..? Or would it disrupt its performance..? This piece really looks promising so i might get one for my intel setup :D
zerospace    0
Looking very nice, Osiris... thanks for posting this :D Now if I could just stop spending money on other stuff, I could pick up an Aquagate mini... :lol:
Guest Mindless Moron
aye me to the aquagate mini seems incredibly reasonable in price and performance but i jsut cant afford it as ive got to move into my new gaff and buy gear to decorate it and my fridge just died, lifes a tad cruel. im glad the aquagate mini fits in the stacker.
merovingian    0
Nice get Osiris!
What is a "gaff" :?::D
Nice get Osiris!
oh yes you lot wouldnt know about such terms.
Gaff or yard: house, home, place of residence, flat, 127.0.0.1
