Mohd Noh    29
On 1/24/2018 at 10:41 PM, Wafflez said:
I have the exact same problem and everything he has aswell. I'm also using a mastermouse s
Hello , last night i get my mastermouse mm520 and is there nothing error i get
Can you print screen the error ?
7 hours ago, Bartosz said:
I have same problem with Cooler Master MasterMouse Lite S.
Hello,
MasterMouse Lite S is plug and play ( no software require )
Mohd Noh    29
32 minutes ago, trosgamer said:
hi same error  mastermouse mm520 connection error
Hello
I am using windows 10 pro 64bit legal key with latest version .
Did you to try uninstall the software + delete the folder ?
Katialuna    0
same issue here. Its also the same issue all over reddit for the past 3 months.
Obviously its a Software issue not a user issue.
Please stop telling us its working and fix the issue.
I have 2 separate pc's both running windows 10 64 bit, both have same issues.
Rav3    0
The same issue please update software or post a guide how to fix the internet connection
Edited by Rav3
Pinkie123    0
I'm having the same issue with the Master Liquid ML 120R Addressable RGB cooler... Just states I need to be connected to the internet. I am! I have downloaded your software and installed 5 times, same issue. Please fix.
Mohd Noh    29
Hello
I will bring this issue to HQ team .
With 3 Pc`s so far i dont get any error msg .
Stay tune , as i mentioned above i will bring this issue to HQ team .
