I downloaded the Portal from CM's website, but when I try to use it, it keeps saying "please make sure that you are connected to the internet when you launch/update the CM Portal".
I've uninstalled and reinstalled it 5 times already. I already tried opening as administrator.
I'm using a Mastermouse S and I am connected to the internet.
Mohd Noh    29
Hi Gab,
Sorry for all of this  .
I will forward this issue to HQ team . Please patient ya . i will update to you once i get any info from them .
Mohd Noh    29
4 minutes ago, Gabriel Gomes said:
What do you mean? Nothing has changed... I still get the same error.
ok noted with thanks , i will talk with HQ again , because i already forwarded this issue , they testing and result no error as you mentioned above . but i will ask them to check it again .
Mohd Noh    29
Hi
Updated : we tested here on at least 3 PCs without any problem
since you mouse was plugged in 2 operating systems win 7 and win 10 and both failed,right ?
RMA the mouse
Please get our customer services for more detail .
Mohd Noh    29
Today im free and installing CM portal for my MasterKey Pro L RGB
The portal is fine but i will try later on with my MasterMouse MM520 will arrive soon .
