baragamer
Pump Noise !! Help
baragamer    0
I have just bought this cooler and the pump has started doing strange noises... I am from Spain so my English is not the best.
I don't think this is a normal noise because It started after a day of use.  I don't know what is happening because I have tried to fix it moving the pump and reinstalling but It keeps making that sound.
Everything is okay, the pump is making that noise.
Do you think I should RMA? Do you know how does RMA work here? Am I going to be without cooler a few weeks?
Here you have the video I recorded:
Mohd Noh    28
Hi Bara ,
Qumu Estas :)
Did you try reinstall your cooling ? and may i know how you put the thermal paste ?
My suggestion as below
As the thermal paste just drop like rice
Make sure don`t over tighten the screw
Try reinstall your cooling , Run 72 hour ) and see how the result , if you still facing same issue , please contact our customer services ( EU team ) will help you .
About the RMA they will assist you .
Thanks .
Mohd Noh    28
1 hour ago, baragamer said:
It is doing the same noise ...
Ok try run at least 72 or days and see how the result + may i know how you install this cooling ?
Please look link below
1, Liquid Cooling: Where do I connect the Fans and Pump?
2, How to determine if the pump is functioning on your liquid cooler
Please take note , if you still facing same problem i suggest you to contact customer services , they will assist you for further action.
Create an account
Register a new account
Sign in
Sign In Now
