Asaf
NotePal XL fan doesn't work sometimes
Asaf    0
I just bought Notepal XL. Its a great cooler but I think I have a problem. When I adjust fan speed controller at the end (highest speed) fan just stops. Then I turn the controller back just a little bit and it works again. Is it a serious problem? Should I give it back to the store? Or it's just an insignificant problem? What do you think?
Mohd Dzuld    7
Hi Asaf ,
Do you have others device ? if yes you can try run the Notepal and you still facing same issue . please touch back the store where you bought .
You still concerned , please contact customer services , they will assist you .
Asaf    0
Thank you for answer. Yes there is still same issue. Then I'll go to store.
Mohd Dzuld    7
And at the same time , please touch our customer services via ticket so easier they assist you .
Create an account
Register a new account
Sign in
Sign In Now
