theforge
Pro 3 cpu bracket
theforge    0
Hi,
My Pro 3 CPU cooler has  detached from my motherboard. I have a LGA1150 socket and am using the push in bracket. The plastic  just above the locking knob has broken and that allows the bracket to come loose. It left the little plastic pieces in the motherboard holes. I was able to remove the plastic parts and now need a new set of brackets. I purchased the fan last year. Are these available and where?
Thanks, Joe
Mohd Noh    29
Hi Joe
Please contact customer services and they will assist you .
