geno
Fans are really loud and has a vibration.
geno    0
I sent in a support ticket several days ago and have gotten no response yet. The 2 120mm fans that came with the masterliquid 240 are loud and one has a vibration that is vibrating my whole case. The loud fans are not due to the air pressure or fan slap. Its more like a grinding motor knock at high speed.  The vibration looks to be a unbalanced fan due to poor milling/manufacturing.
iain b    0
I have the same problem. One of the fans included with my ML240L makes this loud rattling sound. It comes and goes, seemingly as the fans are throttled up and down. Removing the fan from the radiator and then re-attaching it fixes it for a day or so then it's back to the constant rattling. Disconnecting the fan is the only way to keep it from happening. As soon as I plug I plug the fan's power cable back in the rattling starts again.
