Benjamin Gelzinnes
Cooler Master Masterkeys Pro L white
Hello,
I just bought the CM masterkeys Pro L white.
I have several Problems:
1. When I just plugged in the cable in the back of the keyboard and connected it to my PC it wasnt recognized at first I had to play around with the plug a bit and then it started working
2. Now that I can type on it I can't use any of the LED modes. All it does is light up caps lock or  the numlock key when they are active.
Otherwise when I press for example  FN+F1 all it does for me is it opens some windows help site but doesn't do anything for the keyboard itself. I've tried other combinations but it doesn't seem to do anything.
Best Regards
Sunday Morning    179
Sorry late reply
Hi There , do you have others device ? like other pc or lappy ?
Share info i have MKL P RGB run with smooth in windows 7 /10 pro ( Original Windows ) but for that i`m using pirate too :)
and try reset your KB and see how the result . if same issue . please touch our customer services , they will help you .
Create an account
Register a new account
Sign in
Sign In Now
