Dan Jolley
Will this work with Gigabyte GA-990FXA-UD3 Rev.4 Motherboard
Dan Jolley    0
I'm not sure if this is the correct place to post this, but does anyone know if the V8 GTS will fit on a Gigabyte GA-990FXA-UD3 Rev.4 Motherboard? I have all 4 RAM slots full and I read on Amazon that I may  have to remove one or two RAM modules to make this fit. Any advice would be greatly appreciated! I am using a Rosewill Thor full size tower so space is not an issue, there is plenty of room in it. I am currently using an AMD FX-8350 and I will be putting an AMD FX9590 in it and will need the extra cooling. I have a Corsair 750 watt power supply so power is not an issue.
Thanks,
Dan
