Agonizel
H500P - Front Fans RGB
Agonizel    0
Hey people,
Here's the problem: I want a smooth and soothing color cycle like at the demo for my front 200mm fans, but I can't here's why:
- The RGB headers are to big to fit inside my commander pro, I don't even think it would be compatible anyway
- The only place I can connect the RGB header is my Z370 MSI Gaming Pro Carbon motherboard. The problem is, the provided software is Mystic Light which has limited features. I can set a rainbow animation, so there will be a color transition but I can't control the speed of those transitions meaning: The RGB goes at 10'000mph and it looks like a 90's disco party. Mystic Light does not provide a color cycle feature either.
So now, I'm stuck with just one color with no animation.
Does someone have any idea how I can achieve that smooth and soothing color cycle? What kind of tweaking/software/hardware do I need?
Thanks for your answers.
Agonizel    0
Problem solved since a very long time: the factory plugged the rgb headers upside down
Create an account
Register a new account
Sign in
Sign In Now
