Eimis
Why will it not fit
Eimis    0
I recently bought a hyper 212 evo and for some reason on my z270 a pro mother board and i5 7600k it dosnt fit when i screw it on one side of the screws can fit perfectly but then the opposite side goes on a 45 degree angle ans i cannot push it down with force as that just makes all of them pop off
As u might be able to se one of the sides it is and then the oppisit one is on an angle which dosnt let me screw it in
knud    126
You need to secure them in a X-pattern. And don't screw it to tight on each turn. (use you hands to secure them at first)
Create an account
Register a new account
Sign in
Sign In Now
