Todd Whitmore
MasterCase Maker 5 Small Frame
Where can find more information on the small frame (505mmH X 467mmD X 235mmW) for the Maker 5, specifically fan sizes and radiators it would  accommodate? Also, where can I purchase the small frame Maker 5 as I cant seem to find it on any websites and the shop links seem to be dead on the website.
bagziters    6
Hi, which small frame do you mean?
Offical can you take 120 or 140mm fan's @ Front, Top, Rear.
Offical can you mount 240er Rad on the Cooler Master MasterCase 5 Cooling Bracket (on the Top of the case).
It should be incl. fans max. = 55mm thickness.
It can hold an 280 Rad, if you setup a pull Fan-Rad. Fan on the Bracket and down below the 280 Rad. Like this Maker 5 T Thread.
http://www.coolermaster.com/service/faq/mastercase-maker-5t/
https://linustechtips.com/main/topic/452781-coolermaster-mastercase-pro-5-can-it-fit-a-top-mounted-kraken-x61/
https://linustechtips.com/main/topic/494838-ordered-280-mm-aio-rad-mastercase-pro-5-probably-wont-fit-need-suggestions/
http://www.cmstore.eu/accessories-7/
Also you can buy  on your CM Store (US or UK....)
