Dimiter
Only one CPU 4+4 Pin cable in the box
Dimiter    0
Hi there,
I am going to upgrade to x399 mobo and will need to use two CPU 4+4 Pin cables with my faithful V850, but I found out that I have only one of these in the box.
I had checked the official specs and it shows that V850 should come with two CPU 4+4 Pin cables.
Why is this and how can I get one more cable?
Dimiter    0
Just wanted to add that CM support responded very quickly and promised to send the missing cable tomorrow.
Hopefully it will arrive just in time for my build :)
