Patrick Guerrisi 0 Posted November 17, 2017 Hey guys I have a Silverstone SG11 case and no GFX Card I want to know if this CPU cooler will fit in there? http://www.coolermaster.com/cooling/cpu-liquid-cooler/seidon-120m/ I have 75mm clearance in height from the base of the CPU to the top of the PSU I dont have a GFX card so that wouldnt get in the way Share this post Link to post Share on other sites
Mohd Noh 28 Posted November 17, 2017 Hi Patrick , Where you mount the radiator ? Recommend you to get Air Cooling instead Water Cooling . The answer is Not Fit . Share this post Link to post Share on other sites
Patrick Guerrisi 0 Posted November 17, 2017 Yeh I was thinking I might be able to mount on the back or the ceiling of the case but might just be a safer bet to get a low profile air cooler Share this post Link to post Share on other sites
Mohd Noh 28 Posted November 17, 2017 you save man , if you able mount the radiator but when i check you chassis specs is there no place to mount the radiator ( correct me ) and i`m agree with you if you get low profile air cooling + can you share detail about you current system ? Share this post Link to post Share on other sites
