Jos Magallon
Customize possibilities MasterCase 5 pro
@The Cooler Master crew,
Do you have the parts to make it possible to customize the MasterCase 5 pro to a right sided window case with 90° turned motherboard?
Like for example the Silverstone Raven RV02-E, with the cable connections, outtake and IO-shield on the top side of the case and with a right side view in the case.
Regards,
Jos
Edited by Jos Magallon
Crazy49er    0
11 hours ago, Jos Magallon said:
Mmh..no reponses yet, i think i'm in the wrong sub topic.
Maybe it's better that i place this in the feedback section.
I just recently purchased a Mastercase Maker 5 which is the same body style as the 5 pro, from what I've seen you probably could get the glass door and put it on the right side, However you would be doing some heavy modding, metal cutting, and nearly redesign the whole case to flip and rotate the motherboard. An example of something like this would be the Mastercase Tempest build.
knud    128
Like said above, you need to do some (heavy) modding to make something like that to work.
Yep, i saw already that Youtube movie but it's only the back flipped to the up side and not inverted.
There are also inverted (affordable) cases like the Corsiar 600c who could suit me but i really don't like de upside down tekst and/or logo of the GPU.
Al the other 90° inverted Silverstone cases are uggly as h*ll .
PS: i wonder, is the bald frame of this MasterCase 5/5 pro square?
Thinking to mod the case myself.
But can somebody tell me if the temperd glass window fits the pro 5?
If i look at the MasterCase Maker, i can't imagine how the screw connections from the window will fit the pro 5
De case mod is completed and very satisfy.
Very cool temps in the case and barely audible. Especially the GPU stays very cool.
For the record: this mod is not for the fun but because of necessity.
Here a few pics.
First time put together with the parts turn around like i had in mind.
Very handy, those connections on the upper side.
At the rear end the cooler bracket modded to fit the 280mm Kraken X62 rad.
Finish.
