Cathy
Cooler Master MasterAir Maker 8 In a 590III case
Cathy    0
I  have a aus Z370-E  and ordered the Cooler Master MasterAir Maker 8 and the Cooler Master 590 III Window Black USB 3.0 ATX Mid Tower Case .
will it fit in the box and will I be able to put the lid on the box .....one would think buying cooler master it would fit
Crazy49er    0
I just looked it up from a couple of sources that I could find. (Bare with me as I do not work for CM and I'm new here)
It looks like they will be incompatible due to the depth of the case. I put both into PCpartpicker and it lists off as a problem
"Cooler Master - MasterAir Maker 8 66.0 CFM CPU Cooler and Cooler Master - CM 590 III (Black) ATX Mid Tower Case are not compatible."
The Master Air Maker 8 lists online as being 6.8" tall, however the largest cooler I've found installed in that case is the CM Hyper 212 Evo which tops out at 6.26"
Probably not what you wanted to hear. Good luck though!
Mohd Noh    21
1 hour ago, Cathy said:
What no reply from anyone ?
Hi Cathy ,
This is Airmaker 8 specs = 135 x 145 x 172 mm (LxWxH)
This is Cooler Master 590 III specs CPU Cooler = 159mm / 6.2
Too bad the airmaker 8 cant sit into this chassis .
Create an account
Register a new account
Sign in
Sign In Now
