diegopl2
IMPOSIBLE TO REQUEST A POWER SUPPLY RMA
diegopl2    0
Hi from Spain,
I am trying to request a RMA for my dead PSU Cooler Master v1000, but the system throws me the following error and any ticket is generated: "value for restricted picklist field: power supply"
I've tried it several times with different options, but I keep getting the same error. I need to RMA it, Can someone help me? Thanks
Mohd Dzuld    8
4 hours ago, diegopl2 said:
Hi from Spain,
Hola ?
Qumu Estas  :)
By the way can you print screen what kind error you get ?
Update : Talked with HQ team , the system will going up as fast as possible .
Sorry for any inconvenience caused.
Mohd Dzuld    8
Hi,Thanks for the picture , i will share this picture to HQ team + i will delete your picture due to protect your privacy
Update : talked with HQ team , can you select Fan Failure as the failure reason ?
If yes , you can using this one .
Updated : The system has been fixed , you can try again
Create an account
Register a new account
Sign in
Sign In Now
