R.J. Casey
Managing 2 RGB LED Controllers - 1 system
R.J. Casey    0
I bought 8 x Cooler Master MasterFan Pro RGB's. I bought 2 of the 3 packs with a controller and 2 single fans.
So I have 2 controllers, as they only have four slots in them (8 fans).
When I have both of them plugged into my system, the RGB LED Controller software only shows me one controller. I cannot configure / manage the second controller.
Now, if I unplug one, start the software. I can manage that one. Unplug that one, plug the other one in again, I can manage the other. Just can't manage both when they are both plugged in.
Using two separate USB ports on the mobo, they both get identified correctly.
Can this work? It's dumb to have to unplug one to manage the device. Good news is that it keeps its configuration once you've got it set. Just very annoying.
XiTTiX    0
Sorry just to confirm, this will be properly implemented in the future?
Create an account
Register a new account
Sign in
Sign In Now
