John
Is Hyper 212 LED compatible with MasterBox Lite 3.1 case. Specs says yes but PC part picker says no NO
John    0
I need to know if the Hyper 212 LED fits MasterBox Lite 3.1 case. Because according to specs of the case it should just fit. But PC part picker, says they are not compatible at all.. does anyone actually know
Mohd Noh    29
Hi John ,
Chassis clearance higher is 158mm .
And Hyper 212 LED is need at least 160 higher clearance .
try visit link as below for more detail .
Hyper 212 LED
Master Box Lite 3.1
If you still concerned please get customer services , they will give you more detail .
Create an account
Register a new account
Sign in
Sign In Now
