Dmitri S
Bought BitFenix RGB strips - plug not compatible with CM RGB controller?
Dmitri S    0
Bought a BitFenix RGB strip to add to my brand new CM Cosmos C700P. This case came with an RGB controller that controls all the RGB accents on the case itself, but the plug on the BitFenix RGB strip is larger than the plug on the controller. Are these plugs not standard? Does CM sell RGB strip that work with its controller?
knud    125
There should be an adapter plug inside the black carton (toolbox). It's about 10cm long. WIth that, you can connect other RGB products.
Create an account
Register a new account
Sign in
Sign In Now
