charles
CoolerMaster Maker 5t front air intake to restricted
charles    0
My friend just got the CoolerMaster Maker 5t. And while it is a great looking case, his CPU temp is 10C hotter now. The front panel is very restricted it seems
to allow enough air into the case and thus lower the CPU temps. Anyone here have any ideas how to combat this problem? Any help is greatly appreciated!
knud    129
Does he have the MasterBox 5t or the MasterCase Maker 5t?
If the latter, he can always open the front door.
Box 5t, not much that can be done on the front intake, besides upgrading the fans to pressure fans.
  • Like 1
Ben Willis    1
I've got the Masterbox 5 Lite RGB too, just arrived yesterday, and same issue. If I remove the front panel the temps drop about 9 degrees C cooler on my CPU and 7 degrees C cooler on my M2 SSD that sits next to it, and GPU is down about 5 degrees C. These are all idle temps too.
When I install the front panel cover, temps rise within about 3-5 minutes. It's really, really, really poor design with the extremely limited front intake space and the front shroud sitting so close to the case fans leaving no breathing room. This is all with the front fans running at full speed, because although CM remembered to include an RGB splitter, the apparent focus on form over function made them think it was okay to include extremely short fan cables and think it okay to have them run off molex power thus permanently at 100%. The ever present hum of maxed fans which provide terrible airflow is going to drive me nuts.
I'm definitely thinking of returning the case and going with something from Fractal or Corsair instead.
CM should be shipping out replacement front panels that are larger in dimension and allow for proper airflow and at least a 3pin fan splitter that allows the fans to spin up/down via motherboard (or fan controller/hub) to customers who thought they were buying a higher tiered product.
I would forgo RGB and tempered glass panels to get a case which is quieter under desktop operation and actually allows airflow, although the competition manages to offer many/most/all of these things no problem.
Edited by Ben Willis
  • Like 1
charles    0
@knud, he has the the MasterCase Maker 5t. But you shouldn't have to do that.There should be ample airflow while the front panel is in place.
Sunday Morning    174
Hi Charles :)
Just Curious 2 thing
1, What actually the maximum temp on Idle and load? if the maximum temp is below 70,then it is normally i think .
2, What kind cooling you friend using ?
Jay    0
I have  a MasterBox Lite 3.1. It has the same issue you described.  I end up running my system with front panel removed. My fans are mounted inside instead of the way described in the manual.
The difference in air flow with the frontal panel on and off are pretty obvious.
Edited by Jay
Zlata    0
I have the same problem with Masterbox 5T. Currently I'm running my system with front panel off to get any semblance of normal temperatures.
Is there a way to switch the glass front panel to a mesh one?
Specs are:
AMD Threadripper 1950x (stock)
Noctua U-14s cooler
Idle-max (front panel on) 42°C/72°C
Idle-max (front panel off)   35°C/57°C
Ambient temp: 26°C
