George    0
Hello I have a problem with my masterkeys lite l keyboard.
The problem is that the backlight is stuck to rainbow mode and I cant change it because when i press the FN key with the F1,F2,F3,F4 etc.Nothing really happens and it stays with the rainbow effect.I cant change the speed and the mode either and I cant press the windows lock button.
I would appreciate your help.
Thanks ;)
rhyghie    0
My Mastekey lite L keyboard, the RGB lights are not working properly, sometimes they light up, but most of the time the lights are too dim that you can't almost tell if there is a light on the keyboard. it works when i got them 4weeks ago, but not use the keyboard after 3weeks when i receive them. so for just 1week of use the RGB are no longer working properly, which the reason i purchase the combo is because of the RGB on them.
