KokYong
Does FN + E = Reset all to default works for CM Quickfire Rapid-I keyboard?
KokYong    0
Hi,
Would like to find out as per above subject heading if FN + E = Reset all to default works. Thanks in advance.
Sunday Morning    177
Morning Man , Welcome to CM forum
Where you from man ?
I`m not pretty sure if with FN+E can reset to default ( this is what i`m doing with XTI )
I will ask some one and update to you once i got the reply :) ( BRB )
Update : talked with CM Staff via email the answer is Yes it is the same. FN + E to reset all to default.
XTI and Quick Fire is same way by pressing FN + E to reset all to default
Hope this can help :)
Create an account
Register a new account
Sign in
Sign In Now
