AUGUSTINE ANDLER
Cosmos c700p led not working
knud    126
You are welcome. If something comes up again, please let us know :)
knud    126
Maybe it can be useful for others:
If you press the light button for 3 seconds, it will switch off the lights. And 3 seconds to power them on again.
TheTunnel    0
On ‎10‎/‎3‎/‎2017 at 3:30 PM, AUGUSTINE ANDLER said:
Hello knud. the fans and white lights on the i/o work. I checked the pcb and there plugged in. the case rgb lights,fan and rgb control button on the front panel dont want to work but ths power and reset button do work
Same issue I am having here.
knud    126
Sounds like a broken PCB/board. Best would be to request a new part. (support details are in my signature)
George    0
@knud I need your help !
I have a problem trying to build my new setup.
The case doesn't seem to work (leds - fans - panel)
I am not sure what have I done wrong as I was connecting everything.
The computer boots up properly and all the other things works fine.
I cant find any port for the case (PC RGB IN).
I would be very happy if you could help me!!
Attached photos of build and internal!
BASICALLY THE CASE IS SOLVED!!!! I DIDN'T CONNECT THE SATA CABLE UNDER THE BOARD...
THE PROBLEM NOW IS THAT THE FANS WORK BUT THERE IS NO LIGHT ON THEM!!!
Edited by George
Mohd Noh    28
Hi George ,
Please get our customer services and they will assist you .
Mohd Noh    28
13 hours ago, Philippe said:
I have the same problem. Fans are turning, but there's no lightIMG_0654.jpg.b84bd684c160a5b4599a3ae8c84fce04.jpg
Hi Guys ,
Strong recommend , please touch our customer services , they will assist you .
Thanks
knud    126
Just to make clear, the fans are non-led. Just to avoid any confusion.
fRAGMa    0
Posted (edited)
Hellu there , got nearly the same problem . I bought like 10 days ago the cosmos c700p and build the computer yesterday and the power button etc in front of the case are working but the LED system and the fan aint workin.  I opened up once the small back plate as we can see upwards and the most eastward component near the + which looks laid down. This one has kind of gum next to it . It looked kinda weird as that component looks like twisted instead of beeing vertical. I tried the rgb header 1 and 2 of my asus maximus X hero  and it doesnt change a thing. Am i doing summat wrong ? I unbuild Everything thinking I would have done  something wrong but no, same problem after rebuilding. A shame as I bought on purpose that case in order to pair it with my strix system. I m a bit speechless....
ps: i see in reviews on youtube at times this component aint there at times O_O
ps2: case has some strange markings inside like it was really very fast manufactured and not really well finished :/(bad quality control cough for 300 Bucks)
Edited by fRAGMa
Create an account
Register a new account
Sign in
Sign In Now
