AUGUSTINE ANDLER
Cosmos c700p led not working
Sunday Morning    174
34 minutes ago, AUGUSTINE ANDLER said:
Is anybody else having problems get the case leds to work? I tried multiple sata cables into rgb controll hub and different psu's but i cant get them to turn on? Any clues what im doing wrong
Morning Augustine ,
Please contact customer services via ticket + can you help attach the picture ( how the cables are connected in the controller  ) and full detail your specs .
knud    129
It should be plug-and-play. But there is a small delay before the lights start to glow.
Do you see the visual indicator in the I/O panel - does that one work? Or also not?
Also, please check if the RGB plugs are still plugged into the PCB. (behind M/B tray)
Hello knud. the fans and white lights on the i/o work. I checked the pcb and there plugged in. the case rgb lights,fan and rgb control button on the front panel dont want to work but ths power and reset button do work
knud    129
Alright, let me see if I can find a solution. I'll come back asap.
Also: can you post a picture of the PCB - just to see if there is anything odd.
knud    129
Can you take out the PCB and disconnect the fans and RGB connectors and connect another RGB device (if you have it) - you can use the supplied adapter cable - and see if the issue still persists? If so, it means the PCB is damaged. If not, the led bars and/or fans are damaged (which I doubt).
Hello this is a photo of my pcb with one of my four sata cables connected
Here are the specs for my pc
Mb: asus maximus ix formula
Cpu: intel 7th gen core i5 7600k
Memory: g skill trident rgb 16gb 3200
Gpu: asus strix rgb 1070 8gb
Psu: corsair 850i
Cooler: nzxt kraken x62
knud    129
Are you also trying to control the RGB lights via the Motherboard as well?
Can you disconnect the RGB_IN cable (on the right hand side)? Does that make any difference?
If not, than I'm afraid either the data cable or the PCB itself is broken.
Thanks for your help knud. The problem seemed to fix its self. One day they just turned on and i dont know why
