christopher bogie
advice on replacing fans and about pump fan speeds
okay, first off I have 2 questions.. first off.. i am reading that this is supposed to be on full speed at all times? using hwinfo64, the cpu fan is the fans on this AIO correct? well i dont know if what im using came with my motherboard or what "asus rog crosshair VI hero" but there is this thing thats on my screen a circle with an X.. if I click on it it has silent, standard, turbo, or full speed.. i normally put it on standard when doing stuff that does not need alot of cpu.. but if i game or something i put it on extreme or tubro which takes it from 700 rpm to 2000
when its on 2000 there is a whineing noise im guessing from the fan, or fans..
so my first question is... I have this running to the cpu2 fan header using the y splitter that came with it.. am I doing something wrong? am I supposed to leave it on extreme (2000 RPM) at all times?
my 2nd question is.. im wanting to upgrade, replace the fans.. with 2 of these https://www.newegg.com/Product/Product.aspx?Item=N82E16835608051&ignorebbr=1
NF-F12 iPPC-2000 PWM Fan with Focused Flow™ and SSO2 Bearing
they are 4 pin.. first off will these be good for me to use? they are 4 pin.. will the splitter that came with it work? cause I dont remember if the fans that came with it are 4 pin or 3 pin... and if it wont work.. what splitter will i want to buy? do I want a splitter that hooks two 4 pin fans into one 3 pin? or into one 4 pin?
i want to make sure that i buy the right thing cause its going to set me back $50
I have added an image of my hwinfo64 which shows all the temps and stuff.. this the max on the temps and speeds was gaming on battlefield 1
just in case this will help you answer my question
i have asus rog crosshair vi hero
amd ryzen 7 1800x
2x8 (16GB) corsair vengeance ram 3200
m.2 evo ssd
2TB SSHD
windows 10
Sunday Morning    174
Welcome to CM forum .
Hello Christoper . Just want share with what I've been through with my ( Master Liquid 240 )
Owner ML 240 since JAN 2017 ( Run full speed ) so far run without any fail just last week i changed the fans to my old fans ( Jetflo ) the result also great .
Try read this FAQ : Liquid Cooling: Where do I connect the Fans and Pump? and this How to determine if the pump is functioning on your liquid cooler
If me is Yes and would be nice if you run in full speed ( 2700-2900 RPM )
This one is UP to you , you can choose any after market fans .
Share my old specs i5 4690k with z97x gaming 5 + 16gb Rams ( Idle 25-30c and Load 40-69c )
Well any detail please contact customer services , they will explain more regarding this issue .
Hope this can help you .
i think there is some confusion about the 2000 rpm speed.. the actual pump is running around 2700 , but im talking about the cpu fan speed.. which is the fans on the radiator... if you look on the specs of the masterliquid 240 its rated to go 2000 rpm max (FANS) i think im in pretty good shape.. cause under max load.. gaming at 4k its never gone over 70c.. normally around 60-65c under load.. my main issue is just the sound when i turn it on extreme.. i think one of the bearings in the fan is bad.. i really just need to find out about the splitter.. if I have too i can open up the case and look.. i just hate unhooking everything.. just want to make sure if I buy 4 pin fans if they will hook into the splitter.. cause i dont know if the fans that come with the AIO is 3 or 4 pin
Sunday Morning    174
try double check :) if the sound is coming from your fans , you should get an replacement ( RMA )
Nah i have to check back max for my fans speed will check  :) if im not mistake is 1800-2000 ( be back )
You can adjust the fan speed as you like, some MB bios has limitation on how low you can go though
Nah if we talk about ML 240 oh man the splitter that come with the ML 240 can hook to 4 pin fan no problem
Hope this can help .
I have added an RAR compressed file.. its an audio file.. i show what it sounds like with the AIO fans on 700 RPM, 900 RPM and 2000 RPM
2000 RPM is when the loud sound happens.. u can hear the sound perfectly.. the actual PUMP on all of those settings was at 2,700 RPM so it shouldnt be the pump since its not actually changing speed.. only the fan.. the intake fan also speeds up and the fan in the rear... but the sound is coming from the middle of my case.. the only fans I have in the middle of my case is the 2 fans on the AIO
take a quick listen and tell me what you think.. i dont really want to RMA just cause the fan.. i would have to send the whole AIO back? which would leave me w/out a computer.. ill just order the replacement fans, if the splitter does take 4 pin PWM fans I should be fine... but as you can hear.. when the fans are on 2000 RPM like suggested... it sounds horrible
fan noise.rar
Sunday Morning    174
Dude , Please get an advice from Customer services by creating ticket or via live chat  , they will advise you each single problem cross in you mind .
The ML240 should be in silent operation , this is happen in my system :)
So the best solution is talk with customer services and  they assist you
Update :
so I did order the noctua fans.. and rma'd the fans that came with the AIO.. both came in the mail today.. i will try out the noctuas first.. in the image you posted.. did you change the cpu fan to always be at 100%?
Sunday Morning    174
My answer is Yes and as i mentioned above > You can adjust the fan speed as you like, some MB bios has limitation on how low you can go though .
