Anthony Aiello
V8 cooler is AM4 compatible with bracket mod
To make the V8 cooler AM4 compatible, I grabbed the Cooler Master bracket RR-ACCY-AM4B-R1 from Micro Center. The other bracket RR-AM4B-H212-S1 will not work; there is a large stud from the screw at the center of the X that will push against the V8 block. Anyways, You will need to file the edges of the bracket down slightly as shown in the photo to accommodate the slightly wider V8 block. Once you do that, clean up any of the metal filings and you're good to go. The thumb screws will need to be loosened quite a bit because the V8 block is pretty thick. Hope this helps anyone interested. Also, I did replace my stock fan with a Noctua NF-F12 PWM fan. Works great. Fan removal procedure can be found in the Cooler Master Knowledge Base, but it's pretty simple.
  • Like 1
Managed to find the RR-ACCY-AM4B-R1  with Cooler Master India. Will update it once i get it on my hands and try it,
Can you tell me the temps you are getting on ryzen with stock cooler and after using V8. Thanks.
