Ok, so i've mounted everything, the fans are all good, but the pump is not working. I've got the blue led ( see the pics ) on tho and i can feel hot water in on of the pipes.
Is it just me that thinks the pump is not working, ( and why do i get that in bios ) or something is wrong here ???
Sunday Morning    177
Hi Alexandru , Welcome to CM forum .
Can you try reseat your pump ? seem the pump not allocate with nicely or correctly
My suggestion try reseat and following as below . ( how they mount the pump )
1, How to determine if the pump is functioning on your liquid cooler
2, Liquid Cooling: Where do I connect the Fans and Pump?
3, How to Install MasterLiquid Pro 120/240
Please take note & Remember if you still facing same issue , please contact customer services , they will assist you .
