ace
RGB HEADER CONNECTION ISSUE
ace    0
Hi All,
I've purchased some MasterFan Pro Airflow RGB's however the RGB 4 pins dont fit into my ASUS STRIX-GTX1080TI-O11G RGB headers. It fits into my motherboard (Z270-AR) RGB headers and works fine (with a splitter also), however I cant get it to physically fit into my VGA RGB header. Any solutions/adapters you can suggest?
knud    126
I'm not sure if you need to connect the RGB fan header to the graphics card? Is that something Asus recommends?
Create an account
Register a new account
Sign in
Sign In Now
