Frédéric GUIGUI
MasterLiquid pro 120
   Hi all,
I've installed a MasterLiquid pro 120 on my msi motherboard Z270I Gaming pro carbon ac. Since this moment the cpu, case and m/b temperatures have well lowered.
But, in the same moment, the cpu fan speed has increased enormously, can't have a cpu fan speed under 9000 rpm.
Is this a problem ?, does this speed displayed on bios infos or aida64 really fit the reality ?, since cpu cooler is not only a fan ... Should I be afraid of damaging the Master liquid pro 120 ? I've tried a lot of settings on the bios on smart fan mode but nothing to do (I can only have speed is > 9000 rpm or the cpu cooler  is turned off (0 rpm).
Thanx for your help.
Regards
