pcunleash
Aquagate LCD problem, if you're having
pcunleash    0
Hi, guys. This is Han.
Well, I've done a little research on the LCD problem with Aquagate.
Here's my suggestion.
If its beeping.
1. increase the allowded temperature for both CPU and Coolant.
2. If its still beeping, change the thermal sensor cable with other one.
The Aquagate that I have was ok, and the thermal sensor went defective after couple hours of use. I changed it with some other spare that I had, it seems working again. If you unplug the thermal sensor from the dummy pci, it will beep, so it has to be plugged.
It seems that the problem may coming from a very small piece. So try this method. I solved it after 2 hours struggling with the Evil Aquagate!
Good luck
Grump    0
It is so great that we have such great members from all over the world.
Thanks, Han.
Grump
Alot of the temperature sensors that come in the boxes seem to have been faulty, reading up on a few threads about here. Sad because the rest of the set it so beautifully put together.
