Eduardo Cárdenas
MasterAir Maker 8/V8 GTS
Hello. Currently I have the CM Storm Stryker case and the CM EVO 212 as my CPU cooler. I'm planning to upgrade and get a high-end air cooler so I'd like to buy the V8 GTS or the MasterAir Maker 8 but the main problem is clearance and I'm not sure if one of these coolers will fit my Stryker case. Does anybody know or own these coolers? Thanks.
Sunday Morning    177
Welcome to CM forum .
Hi Eduardo , Qumu Estas ? :) You have great chassis and no need to worry about fit or not because V8GTS and Air Maker 8 can sit into your chassis .
Stryker Specs is   : Max CPU Cooler Height    186 mm / 7.3 in
V8 GTS Specs is  : Dimensions (LxWxH)    154 x 149.8 x 166.5mm (6.1 x 5.9 x 6.6 in)
Air Maker 8 Specs : Dimensions (LxWxH)    135 x 145 x 172 mm
If you still concerned please contact customer services they will assist you .
Create an account
Register a new account
Sign in
Sign In Now
