GG
CM Elite 110 build PSU recommendation
GG    0
Hi. I'm looking to build a pc for my folks (no graphics card) and they would like to keep it small so I will be using the 110 case. Which PSU should I use with it?
I was thinking of a modular one since its a small space, but I don't need much power since there is no gfx card, only onboard graphics.
Also I keep reading stuff about inverting the PSU to exhaust air since there is only one fan in the case, the front intake.
The build is simple: core-13 with Intel stock cooler fan, 1 M2 NVME SSD drive, two sticks of DDR4 Ram and a Gigabyte MiniITX  m/b.
So, PSU recommendations?
knud    127
Any standard ATX PSU fit, but I do recommend something like the GM series PSU, as those are semi-modular, but also "small" in length, which means you will have a bit more space to work with. And those PSU are not too expensive.
GG    0
Thanks!
Create an account
Register a new account
Sign in
Sign In Now
