David
MasterFan Pro RGB LEDs dim/not working
David    0
I just bought the MasterFan Pro Air Pressure RGB Case fan. The fan itself is working fine, however the LEDs do not seem to be working properly. I do not have an RGB controller so am just using the red or blue settings. When set to blue, the LED lights up for 1 second on startup and then turns off. When set to red, the LED stays on but quite dimly, and flashes to full brightness for 1 second when the computer turns off. I have tried two different system fan plugs with the same result. Is there something I can do to fix this, or is the product faulty?
Portshot    0
For anyone having this same issue looking for answers... if your fan speeds are controlled by the BIOS to adjust speed as needed, or if they are set to a quiet mode, the fans spin slower and the LED is dimmer, or off. When powering on the system you might get a bright flash as the computer POST. In Windows, using the ASUS Ai utility for Fan XPert, if I click "full speed" I get the full brightness... if I click "quiet" mode the LED dims a lot.
The LED power for these fans is provided by the power connector, NOT the RGB wire.
Mohd Noh    29
Hello
Sorry late
Share what i am doing , i have old board z97x gaming 5 and i bought some masterfan pro 120mm x5
To turn on an RGB light i have to get RGB controller and some PWN Splitter
Updated : Done doing some installation with
1 , MasterFan Pro 140 with RGB controller
2, MasterFan 120x 3
3, MasterLiquid ML 240 L RGB
4, Splitter 1x4 PWN
5, RGB Splitter 1x4
20180215_225914.jpg.38e60c1e7aef3bb9ff5a62ea577643a9.thumb.jpg.f9e7871a10b6186aaa3aba2b5e120d67.jpg
