PenDragon
Repair QuickFire TK led
PenDragon    0
How to I fix the backlight of my "QuickFire TK".
Its the left Control Key and Enter key. unfourtunetley the keys I use the most, they are flakey most of time, not as bright as the rest. I have tried many times to remove the keycap and slightly move the led just a little bit with a tooth pic and that normally works for a while then it goes dim and weak on me again.
knud    128
If you know how to (de)solder, you can try that. Or replace them altogether - however I don't have the tech specs of these leds.
Or if you are still in warranty period, apply for RMA.
PenDragon    0
Extremely dissapointed  Bought it for its size for typing in minimal light and desk space, I don't game so rlly any cheaper model would have done. I thought I was paying for quality cause everything else is pretty basic, from the one color led to the lighting modes to the zero software that came with it.
Every other day a key starts dying on me..
knud    128
In that case, I really advise you to apply RMA for it, because the leds should not be dying, at all.
Create an account
Register a new account
Sign in
Sign In Now
