Brandon Cullen
Trouble installing top and rear case fan maker 5t
What the title says I had a real struggle pushing those screws in I used the right ones the case said and those were a bit easier then the supplied screws from the fans. I used the Corsair HAD RGB 120 for both top fans and rear fan. I had no issue unscrewing the supplied rear fan and moving it into the front but when I tried to put those fans in I really couldnt get it.
As you can see those screws we're really forced in the case it didn't seem to damage the case though it was just very hard to get in. And it was very hard to get them in straight.
Sunday Morning    174
I know how you feel man :)
Just share my pro 5 , For first time will be tight so i put some // a bit oil between the fan hole and the screw .
But if you still concerned i love suggest you to contact customer services they will assist you .
  • Upvote 1
