naripeddi
Cooler Master Evo 212 compatibility with Cooler Master K380 case
naripeddi    0
I have a Cooler Master K380 case with Intel i7 4790K processor mounted on Asus Z97-A motherboard. The stock cooler isn't giving enough cooling as a result, the machine has been restarting after BSOD whenever there is load on CPU. Can I fit Cooler Master Evo 212 in this case (CM K380)?
Sunday Morning    177
Welcome to CM forum .
Hi Naripeddi , Unfortunately K380 Cant Handle the Hyper Evo 212
K380 : CPU cooler height: 155 mm / 6.1 inch
Hyper Evo 212 : 120 x 80 x 159 mm as attached below :
naripeddi    0
Thank you Mohd for the confirmation. If Evo 212 cannot fit, what is the next best cooler from CM that I can use in this case? Is Hyper 103 good enough? I use i7-4970k (not intending to overclock at all) on motherboard Asus Z97-A.
