Edwin Hunter
Finding fan/led controller compatible light strips
So I acquired my case recently however I hit a snag. The current connectors on the controlled are a 2 pin connector and all the new light bars are a sata 12 pin; is this simply an outdated format that is no longer used or is this a coolermaster only connection type and if so why am I not seeing any new lighting options with this connector. I want to light the case further with a few other colors and items but without the connection type the led controller is useless. Anyone got any help with this topic to drop on me
knud    125
At the moment, only 2pin led strips are supported on this chassis (Either Maker 5 or Maker 5t). And those only exists in red color.
The SATA ones are meant to be universal. However, you can make them work with the controller, but requires some modifications.
Create an account
Register a new account
Sign in
Sign In Now
