JK
Fan too loud
JK    0
Guys, I just installed the Masterliquid Pro 120 and the fans are rather loud. Is there any way to adjust the fan speed? Or is it possible to change the fans to silent fans?
Appreciate the help. Thanks.
knud    129
You can let the M/B control the fans. In most scenarios, there is no need to set the fans to maximum speed. (just set the pump to 100% speed).
You can also replace the fans with either balance or pressure fans.
