Moha
Elite V2 550 WATTS problem !
Moha    0
hello guys !
i have an issue with my power supply  Cooler master Elite V2 550 watts , i brought it few months ago and since i brought it every time i run a game , power supply fan speed up (psu does not get hot it's just fan speed up) i hope someone advice me of what should i do with this fix or replace it :)
knud    128
Sounds quite normal to me: the PC (and therefore the PSU) is getting under load. Which means, the fan needs to turn faster to keep this PSU cool enough to work.
This is a budget power supply, which also means, the noise level is not the quiets. You could look into the GM series for example as a possible replacement/upgrade.
  • Upvote 1
Moha    0
i'll upgrade it to better one , what psu can u suggest :) ???(i have AMD A8 7650K+Motherboard A88X+gtx 960 4gb msi+8GB RAM )
Edited by Moha
more details
knud    128
Cooler Master GM 550w will be sufficient. Or if you want something more energy efficient - but at a higher price - V550.
  • Upvote 1
Create an account
Register a new account
Sign in
Sign In Now
