Narciso
mount upside down?
Narciso    0
Hello guys, so i'm having a problem. The pump from the cooler is very big and i can only use a slot of ram, i only have 2 slots of ram because i use mini itx board.
So the question is, can i turn upside down the pump of the 240? that way i would have spcae for the other ram
Narciso    0
This is how i have now because the pump makes pressure on the left ram and i can plug it in.. i was wondering if i can invert the cooler upside down so the pump be on the left side. thank you.
Sunday Morning    178
Sorry late reply .
You can check this link :
1, http://www.overclock.net/t/1419639/considering-adding-more-storage-to-my-evil-angel
2, http://images.hardwarecanucks.com/image/akg/water_cooling/Seidon240M/CM_Seidon_240M_intel4.jpg
My suggestion , You can try rotate 90 degree and monitor the temp
Create an account
Register a new account
Sign in
Sign In Now
