Shaun
High temps
Shaun    0
MSI Command Center is showing my 1800X is 50 C at idle, and 80 C under ~80% load. From this cooler's reviews these number should be much lower. The radiator fans are always loud, too. There appears to be good contact between the CPU and the block. I do hear bubbling from the pipes occasionally.
System
AMD 1800X
MSI Carbon X370
Dumb as balls Corsair Carbide Quiet 600Q case
2x120mm (front) and 1x80mm (rear) fan exhausting, the two 120mm fans on the radiator are input (bottom)
1x560 Ti
Seasonic fanless PSU
Edited by Shaun
Sunday Morning    174
Welcome to CM forum .
Hi Shaun , My suggestion as below
1, try reinstall your you cooling + make sure what you did is correct
a , How to determine if the pump is functioning on your liquid cooler
b, Liquid Cooling: Where do I connect the Fans and Pump?
2, Contact CM customer service if you still facing same problem .
Hope this can help .
