Jorge Garibay
Masterbox lite 5 cant fit 3 120mm case fans
So im trying to put in my 3 corsair af120 fans in the front and i cant seem to get all 3 to fit. the manual says it supports 3 120mm fans so im confused what im doing wrong. Where exactly do the other 2 need to go? or do i just have the bottom fan to high?
Sunday Morning    179
Welcome to CM forum .
Hi Jorge , Can you try install the fans start from the top ?
Below is some picture for your reference
If you still facing same issue . please contact customer service , they will guide you .
Hope this can help .
  • Upvote 1
knud    126
There are extra plastic plugs in the package. And you can also use regular fan screws.
  • Upvote 1
Create an account
Register a new account
Sign in
Sign In Now
