Catalin
Liquid Nepon
Catalin    0
Dear friend , i comeback for another reason. I changed my board, to asus x99 deluxe 2 from asrock x99oc formula
There you told me what to do, at Asrock x99 OC formula, to put the pump on a chassis fan and the fans at the fan cpu. At asus x99 deluxe 2 what can I do to stop taking control Nepton 280L?
There are times when fans do not turn around
I'm waiting for a reply from you
Sunday Morning    174
Hi and welcome back :)
Did you try to connect like you do previously ? You can try
1 x Water Pump header (4-pin) for pump connector
1 x CPU OPT Fan connector(s) (1 x 4 -pin) for fans connector
Catalin    0
i tried to do asrock motherboard
I put the two fans on a single fan cpu
I gave optimizations in bios and always give me the message at bios start, speed to low etc, cpu fan error. is there any error from bios?
Because I put and separate, normally, one vent to the fan cpu and the other to the fan eight fan and the same
Catalin    0
I solved. I put the fans on the fan and eight and pump it to the pump and it goes
Asus has a very low setting on the fans, somewhere at 300 rpm
It's fine now, like cooling. Thanks for the answer
Mohd Noh    29
you welcome :)
  • Like 1
Catalin    0
I come back with a question:
I changed my CPU and motherboard, now I have a 7980x and a x299 fatality Proff i9 Xe.
At Nepton 280 we have a Noctua industrial 3000 pwm fan
With the motherboard and bios settings, they get only 2500 rpm, although the maximum is 3000 rpm
How can I make use of all the fan speed I have?
or at least 2800
