Catalin
Liquid Nepon
Catalin    0
Can I help take a new one or change that I have it?
because I did not understand
Edited by Catalin
Catalin    0
On 07.06.2017 at 9:31 AM, Mohd Noh said:
Please submit an ticket at here : https://account.coolermaster.com/LogOn.aspx
Customer services will help you :)
And look this too : Nepton 280L
Oh ya you can try CM new products at here : COOLER MASTER MASTERLIQUID PRO 280
what differences it is between nepton 280l ANd master liquid pro?
After i see CFM, i see Nepton is much better and most powerfull,
Wright?
Sunday Morning    174
Wright?
Fan life expectancy is longer than Nepton 280 and the Radiator comes with with new technology ,The MasterLiquid's unique square fin design creates greater surface area for absorption of the heat and allows for spacious airflow. The increased space means we can use a quieter fan that pushes air farther out of the case. It's really quiet.
also creating more surface area,657%, from which the coolant can take away heat up and for you information the Nepton 280 has discontinued .
If me i will try new design :)
